DXO to PSU nef thumbnail problem
peterpix
Post by peterpix » 11 Apr 17 11:24
When I open a NEF file in DXO Optics Pro from Photo Supreme, and then process in DXO and close it, the thumbnail in PSU changes from the original NEF thumbnail image to a weird cross-processed look (see attached comparison). If I do it again the weird PSU thumbnail gets darker. Running rebuild thumbnail doesn't fix it.
The NEF file itself appears to be unaffected. When I use Windows Explorer to look at the directory, the thumbnail is like the original. So I have to conclude that it is PSU misreading the data in the NEF file or the sidecar or DOP file.
Does anyone have any idea how to fix this?
Peter
Re: DXO to PSU nef thumbnail problem
Post by fbungarz » 11 Apr 17 16:29
Which DxO version are you using. I used to have big problems with DxO 10, those are gone in DxO 11.
peterpix
Post by peterpix » 11 Apr 17 16:45
Hi, I am using 11 too.
Peter
Post by Hert » 12 Apr 17 22:37
How did you set DXO support in PSU's preferences? Disable it if you don't want it.
