Copy Portfolios to new database?
Larry56
Post by Larry56 » 28 Jan 17 4:23
I've created a new catalog and am in the process of fixing out of sync photos. I haven't had any problems that I've seen as far as importing metadata basic info but Portfolios are not imported. For that I assume they are only recorded in a database.
Any suggestions on how I could import Portfolios into the new catalog?
PSu 3.3.0.258 on Windows 10.
Re: Copy Portfolios to new database?
Post by jstartin » 28 Jan 17 12:13
I believe that if you enable writing and reading of the ICS schema during sync that portfolios should be recreated as the relevant images are imported.
Jim (Photo Supreme: AMD Quad-Core A8-5500 Accelerated Processor 3.2 GHz; internal AMD Radeon™ HD7560D; 4GB DDR3 SDRAM; Win7x64)
Larry56
Post by Larry56 » 29 Jan 17 2:21
Thank you. I thought I'd checked that box but now I see I just had it checked for Write and not Read. Changed in Read tab and did a test import and the portfolios were updated.
Post by fbungarz » 29 Jan 17 20:04
Don't forget to uncheck read after you are done, else you are headed for quite a few unpleasant surprises. There is a reason ICS reading is disabled per default - the database can be messed up if both read and write are enabled simultaneously ...
To be secure, reading should be enabled ONLY temporarily during import, re-creating a new database. Ideally during that process you then should turn writing OFF. Once you are done, you then should enable writing again and turn reading off.
Larry56
Post by Larry56 » 30 Jan 17 17:07
Thank you for the warning. I'll do that right now.
