Sharing by email - caption line
Post by Stephen » 01 Jan 17 20:42
A very happy new year to Hert and all participants!
Using the function >Share >By Email
Does anybody know how to add a caption line to the body of the email below the image(s) being sent please? Clicking on the Caption Signature and editing it allows a variety of options, but the caption line text always appears within the image and not below it, like a watermark.
Added for clarity:
Sharing by email is useful to show anybody a selection of images from which to select which they want. Currently the recipient has to return the selects and delete the others, rather than by just quoting the captions (or file names) beneath the images. It can be difficult on this end to determine which images those are, if, i.e. they are portraits with only minor differences in the expressions.
Both Psu functions 'watermark' and 'caption' are very similar. However, a caption is normally used beneath an image. Adding text within an image is distracting and involves an extra step if it then becomes necessary to resend the selects without the integrated text.
PSu currently adds the following text in the body of the email, so we know that the requested function is possible:
"Im sending you the attached image sized and sent with Photo Supreme". The question is whether this caption text can be added below individual images?
Perhaps I just cannot find the magic button?
Re: Sharing by email - caption line
Post by Stephen » 10 Jan 17 18:44
Any ideas please?
Post by fbungarz » 10 Jan 17 20:09
I would actually quite like to know how this works myself, especially if it is possible to include not just any caption, but a specific one, i.e., from a specific xmp field. That would be great!
However, right now I don't even have a clue how to simply add the file name as a caption :?
Post by tstoddard » 10 Jan 17 20:32
I can't think of any way to do it in PSU today. You could create a feature request, although it could be difficult to implement well. I'm sure Hert could create html templates that could do what you want but creating ones that would display consistently in all of the different email clients being used these days could be challenging. This really sounds like a task better accomplished by using a sharing site. It would be far more efficient to send links to images than to include multiple images embedded in the body email messages.
Post by snowman1 » 11 Jan 17 3:00
This will be very dependent on your operating system, email client, etc - but you could use PSU to share to a (temporary) folder; select the images in the folder; right click in windows explorer and "send to email". Did a quick test using W7 and Thunderbird and this created a message with the images as attachments, a subject line that said
"Emailing: 20170102_162156_Lumia 635_WP_20170102_003.jpg, 20170102_162109_Lumia 635_WP_20170102_001.jpg, 20170102_162125_Lumia 635_WP_20170102_002.jpg"
and a body that said
"Your message is ready to be sent with the following file or link attachments:
which if I understand correctly is the kind of thing you want? Not a great solution but if it works for you, and at least it's easy to do.
Snowman1
Post by Stephen » 16 Jan 17 21:27
fbungarz wrote:I would actually quite like to know how this works myself, especially if it is possible to include not just any caption, but a specific one, i.e., from a specific xmp field. That would be great!
If you click > Share >manage > email transfer > caption signature > click on caption signature > my caption > edit captions, then you can add almost any xmp field you wish. However it (they) appear within the confines of the image and so they are NOT captions, but watermarks.
This leads me to question what the difference is to the watermark signature?
@snowman
Thanks, I tried your suggestion under Mac using the default mail client (called Mail) but it does not transfer the file names, only the files.
Post by fbungarz » 16 Jan 17 22:20
Hi Stephen,
thanks much for explaining that !!!
I agree: it seems odd indeed, if the captions are added as watermark. :?
Post by Stephen » 16 Jan 17 23:18
I have filed a Mantis report:
http://mantis.idimager.com/view.php?id=3148
Larry56
Post by Larry56 » 20 Jan 17 21:00
Thank you Stephen for submitting to Mantis and posting the question in the first place. It never occurred to me that I could send captions with emailed pics. I was disappointed that it does appear they are sent with watermarking instead but I hope Hert will make a quick fix to this feature.
Post by Stephen » 24 Jan 17 3:35
Thanks. Please show your approval by adding your comment to Mantis.
Post by Stephen » 19 Jul 17 14:16
I see no progress on this Mantis report:
Does this affect other people's workflow as it does mine?
Larry56
Post by Larry56 » 22 Jul 17 19:38
I joined you in Mantis on reporting this. As I recall the last time I looked at it, it's been assigned to someone but I don't know what that means as far as time. I do wish it would get fixed though.
Post by Stephen » 01 Aug 17 18:10
Latest update from Mantis:
“Captions are not the same as watermarks. A caption is a text that you can add to the image. A watermark is a graphic you can add to the image. Captions are drawn on the image. I understand that this feature request is for a caption below the image. That means a change to how the software works and if such changes are picked up depends on the demand for it.”
I entered this Mantis request conservatively as a feature, waiting for confirmation from others, whether they saw the same results. I then changed my opinion that it’s a bug (but this category is locked and cannot be changed in Mantis).
However, this presumption is based on my learnings, where the caption is a title or description of an image, which in traditional newspapers appears immediately below the image.
Other languages describe it similarly; leyenda, légende, Unterschrift.
It is not a watermark, which can be in image or text form and is superimposed over the image. An exception might be in the film industry where captions (plural) can be superimposed over the image. While PSu can manage a film database, I do not consider that to be the product’s major focus.
I don’t want to dwell on semantics of words, but the 2 very different terms used in PSu to describe basically the same feature has lead to this confusion.
I also don’t understand the difference in the steps needed by a software engineer to superimpose a file name, title or other metadata or to put them beneath the image in the body of an email. PSu does however elegantly manage to add:
“Im sending you the attached image sized and sent with Photo Supreme” to the body text and also inserts “My Photo Supreme Images” into the subject line.
It appears that we might have to wait for this to happen. I for one was expecting PSu to do something for which was apparently not designed. It would be extremely useful though.
