to DxO and back
vkfoto
to DxO and back
Post by vkfoto » 10 Nov 16 3:08
I sent a JPG to DxO for some processing via the External Application link. After doing some work it was exported back to the original folder with a suffix _DxO to be able to compare before and after, but in order to see it, I had to run a Verify Folders. Perhaps my computer is not the fastest on the block but 460 files takes a while. Is there a faster way to add a single new image to the catalog?
barneagle
Re: to DxO and back
Post by barneagle » 19 Nov 16 22:54
I haven't used it, but I noticed that in the File menu there is an option to Import Single Files. (Also, you can verify just one folder by right-clicking on the folder and choosing the option from the context menu.)
