SOLVED 3.3 server with PostgreSQL not finding server
HCS
Post by HCS » 16 Jul 16 20:21
Hi, i'm using the PostgreSQL server version on a MAC.
I've updated to 3.3 today and the client cannot connect to the server, throwing the following error: "Unable to connect to the database. The database reports: Can not load PostgreSQL client library "executable_path/libpq.5.dylib". Check your installation" (see attached screen print).
Did anyone encounter this as well?
I've also downloaded the server package from the web site, but it throws the same error.
I cannot access my database now.
[Hert; edited title by adding that this is PSU-Server-PostgreSQL related]
Screen Shot 2016-07-16 at 21.15.19.png (34.08 KiB) Viewed 2380 times
DirkS
Re: 3.3 server not finding server
Post by DirkS » 16 Jul 16 23:12
Mantis ticket http://mantis.idimager.com/view.php?id=3038 seems to describe a similar problem on Windows.
I don't know if Hert made any changes to PSU to solve the issue, though.
I would suggest creating a new ticket on Mantis.
HCS
Post by HCS » 17 Jul 16 8:56
OK, thanks. I will do that.
amartel
Post by amartel » 17 Jul 16 13:07
I had the same probleme.
I just downloaded the updated package (uploaded today) and, now, PSU is running OK.
Thank's a lot Hert !!
HCS
Post by HCS » 17 Jul 16 13:21
I can confirm that it now works with the Fix provided by Hert.
