Photo Supreme v3.3 postgresql on macosx
Locked
amartel
Post by amartel » 16 Jul 16 17:50
Hi all,
v3.3 is now released and I installed it today. I don't know if there is something wrong with my mac but I can't run PSU v3.3. I have the following error message after trying to login (I'm french):
Connexion à la base de données impossible.
Rapport de la base de données:
Can not load PostgreSQL client library "@executable_path/libpq.5.dylib". Check your installation.
If I uninstall v3.3 then reinstall v3.2, Photo Supreme is running OK (so it seems to be related to v3.3).
My configuration:
MacBook Pro - macosx 10.11.5
PostgreSQL server 9.5.2 (on NAS synology)
thank's for any suggestion...
DirkS
Re: Photo Supreme v3.3 postgresql on macosx
Post by DirkS » 16 Jul 16 23:06
Someone else posted the same issue. See http://forum.idimager.com/viewtopic.php?f=57&t=24241
Please continue discussion in that topic.
Locked
