Deleting a catalog?
C-F
Deleting a catalog?
Post by C-F » 28 Jun 16 3:33
I am new to Photo Supreme and use the trial.
I ran a test catalog before reading some of the informative posts on this forum and now decided to start over from scratch. I can not find a 'delete catalog' option in PSu menus.
So, how do you delete an existing catalog with all its contents?
Thank you.
PS, MacBook Pro retina user.
Re: Deleting a catalog?
Post by Hert » 28 Jun 16 22:42
You can delete the catalog file (make a backup in case you want to go back)
1. Close PSU
2. Start Finder
3. Use Cmd-Shift-G and Visit ~/Library/IDimager Systems, Inc./Catalog
4. Delete (or rename the existing catalog files)
5. Start PSU
C-F
Post by C-F » 29 Jun 16 0:43
Thank you!
oston
Post by oston » 06 Sep 16 19:25
Please could you give the instructions for a Windows 10 OS
oston
Post by oston » 07 Sep 16 19:12
No need for a reply to the windows question. I found the answer in the preferences
peterglass
Post by peterglass » 28 Oct 19 0:42
How do I delete one or more catalogs in Windows 7?
Post by Hert » 28 Oct 19 8:13
Hi Peter, first of all, a warm welcome to the forum.
1. Close PSU
2. Start Windows Explorer (Win+E)
3. Go to the folder %localappdata%'IDimager Systems, Inc.\Catalog (enter it like that in Windows Explorer)
5. Start PSU
peterglass
Post by peterglass » 30 Oct 19 4:12
Thanks for the welcome and for the answer to my question.
Peter Glass
