Versioning (NEF + TIF + JPG)
NassauBoy
Post by NassauBoy » 09 Apr 16 17:09
Im still struggling with PSu not being able to give me a decent render in the thumbnails to represent the work done in C1. I can start with the crop. Cropping in C1 does not appear in PSu for me at all. So my workaround for now (experimenting still) is to create JPG and TIF in C1.
For those of you that use C1, the TIF are in the Select Folder of the C1 Session and the JPG are in the OUTPUT folder.
When I import the NEF and JPG and the TIF what I would like to happen is that FILE01.NEF, FILE01.JPG and FILE01.TIF all create a version stack in PSu. Basically Im able to see I have 3 versions of the same image. Pus seems to be versioning just 2 images (NEF and TIF). Pus sees the JPG but does not version them to either the TIF or the NEF.
Just wondering if Im missing something.
Late 2012 27" iMac 3.4Ghz i7: 32GB Ram: Internal SSD: External Promise R4 Thunderbolt 16TB Raid 5 (all Data)
Re: Versioning (NEF + TIF + JPG)
Post by vlad » 09 Apr 16 23:33
NassauBoy wrote: When I import the NEF and JPG and the TIF what I would like to happen is that FILE01.NEF, FILE01.JPG and FILE01.TIF all create a version stack in PSu. Basically Im able to see I have 3 versions of the same image. Pus seems to be versioning just 2 images (NEF and TIF). Pus sees the JPG but does not version them to either the TIF or the NEF.
Do I assume correctly you selected "RAW as main version" as your versioning rule in the import profile?
My understanding is that the importer module was designed to detect and create version sets only based on image pairs, not on image triplets etc. The understandable wish to remove that limitation was recently mentioned in a seperate thread, but I don't remember if it's already recorded in Mantis.
