possible to re-arrange label set sequence?
Post by fbungarz » 19 Feb 16 11:10
I have quite a few label sets in the Assign Panel now.
The standard set is RECENTLY USED, FAVORITES, SUGGESTED, NEARBY LABELS.
These are not alphabetically sorted - fine, makes sense.
My own label sets, however, are apparently per default arranged in alphabetical order. During a session I am often using only two or three open panels, the others are collapsed. Is it possible to sort label sets manually?
Why would I want to do that? For example, say I have these sets:
A
B
C
D
E
F
G
Now, I use A and F.
B to E and G are collapsed, but take up quite a bit of space...
This means, I regularly need to scroll up and down, move between sets A and F and cannot just quickly click the labels that I want to assign.
Being able to re-arrange the sets, would much improve that, say:
A
F
B
C
D
E
G
Is that possible?
