Keyboard shortcut to copy/paste labels
Roman
Post by Roman » 18 Oct 15 11:02
I know you can copy/paste labels from from one image to another using the label assignment search menu but I don't believe there are keyboard shortcuts to copy/paste labels from one image to another. I think in some circumstances keyboard shortcuts for these functions would speed up the label assignment process significantly. Is there a way of customising keyboard shortcuts to perform this function?
Regards,
Roman
Re: Keyboard shortcut to copy/paste labels
Post by Hert » 18 Oct 15 11:38
I can't double check it now but I believe there is a shortcut for that. Did you already check the keyboard shortcuts in the document from the Help menu?
Post by Mike Buckley » 18 Oct 15 13:19
The two shortcuts are identified in the Help screen's Keyboard Shortcut Reference but they're not identified in the dropdown menu that is used to copy and paste using a mouse.
Windows -------- MacOSX
Alt+Shift+C -- Opt+Shift+C -- Copy catalog labels assignments for selected thumbs to the clipboard
Alt+Shift+V -- Opt+Shift+V -- Paste catalog labels assignments from clipboard to selected images
Roman
Post by Roman » 18 Oct 15 20:35
My apologies, I had a browser bookmark for the keyboard shortcuts but it was still pointing to the V2 shortcuts page.
