Multiple Monitors
weisswelsh
Multiple Monitors
Post by weisswelsh » 07 Oct 15 20:26
I have three monitors with my main monitor in the center. I have photo supreme set to open pictures in a second monitor. It has always done this by opening up in the monitor on the left. Now it suddenly is opening up pictures on the monitor on the right. Is there some way to set Photo Supreme to open in the left monitor again.
Bob
Re: Multiple Monitors
Post by Hert » 08 Oct 15 6:53
Maybe the sequence of the monitors changed in Windows? PSU uses the "second monitor" to the one reported as the second monitor by Windows
tumirnix
Post by tumirnix » 11 Oct 15 12:57
Hi Hert!
IDimager wrote:Maybe the sequence of the monitors changed in Windows? PSU uses the "second monitor" to the one reported as the second monitor by Windows
I have also the impression, that PSU starts always on the first monitor (the one with the Windows tasklist). But when I move it to the other screen (Shift+Windows+Left or Right), then the pictures/light table are always opened on monitor 1.
Please take a look on the Feature Requests
http://mantis.idimager.com/view.php?id=2805
and
http://mantis.idimager.com/view.php?id=2806
which describe similare problems (and have not been answered since February).
Best regards
Martin
Reason: fixed url
tumirnix
Post by tumirnix » 21 Jun 16 21:54
Hello again,
somehow I'm not sure, if the requests in Mantis are really considered.
tumirnix wrote: Please take a look on the Feature Requests
and
"February" means February 2015!
I.e. no answer or comment for more than 15 Month. My other 6 requests are in a similar state.
Regards
Martin
Post by Hert » 21 Jun 16 22:18
They are requests and requests may or may not be picked up. You haven't had support on the ticket from other users. By logging a ticket you have made sure that it remains in view. My guess is that a typical multi monitor setup will have the better monitor as monitor 1.
tumirnix
Post by tumirnix » 09 Jul 16 21:34
thanks for the reply.
Hert wrote:My guess is that a typical multi monitor setup will have the better monitor as monitor 1.
My motivation to have the better monitor as monitor 2 is that I do not want to waste the space with
e.g. the taskbar (ok, I could let it disappear).
Best regards
Martin
