Import
LifeIsLong
Import
Post by LifeIsLong » 16 Aug 15 18:08
is there a way to delete files from the disk while culling them in the importer?
My actual dilemma is that while culling I often want to remove an image from the viewer so I don't have to keep going back over it. Some images are obvious deletes. I pressed delete and the dialog came up about deleting from catalog/disk. I clicked disk, but nothing happened.
Re: Import
Post by vlad » 17 Aug 15 10:36
I can confirm the reported behavior - it seems like a bug. In addition, I don't think the delete dialog should offer the option of removing the image from the catalog, unless the image had been imported before and is still in the database.
These are good issues for a Mantis report.
LifeIsLong
Re: Import
Post by LifeIsLong » 18 Aug 15 1:16
Yeah I wondered about the catalog entry as well. I created mantis ticket http://mantis.idimager.com/view.php?id=2902 for the delete operation.
