External App links have stopped working
Post by Stephen » 06 Apr 15 16:51
My links to Aperture, Capture One, etc have stopped working. Could it be a bug in the latest update 3.1.0.2067?
Paul C
Re: External App links have stopped working
Post by Paul C » 07 Apr 15 15:47
I'm on 2067 and they seem to work for me.
Preston B
Post by Preston B » 07 Apr 15 17:12
Stephen,
In PSu, go to Tools>Preferences>Other Settings. You can add or remove external applications there. In your case, check to make sure the path(s) to your external apps are correct.
I upgraded to V3 build 2067 today and my external app (Photoshop CS6) opens just fine.
--P
Preston Birdwell
Columbia, CA
Post by Mke » 07 Apr 15 19:24
Perhaps this is because you've moved the Photo Supreme AppData folder (which includes the locations of linked applications) from C:\Users\MyAccount\AppData\Local\IDimager Systems, Inc to somewhere else?
If so, when you update PSU, a new shortcut will be created that doesn't know this. You need to edit the shortcut to add the path to the appdata folder using the -a attribute (or fine the old shortcut and delete the new one). It should be in the format:
"C:\PathToMyCopyOf\IDimagerSU.exe" -a "Z:\PathToMyPsuAppDataFolder\IDimager Systems, Inc"
Post by Stephen » 09 Apr 15 17:33
Sorry, this problem was solved shortly after I initially posted it. I tried to delete the thread but apparently I only deleted my comment that it has been solved. Sorry and many thanks.
