Editor on external computer
Post by Stephen » 27 Mar 15 17:00
I want to use an editor (Capture One) which I will install on an external computer running a more recent OS than the one running on the computer where Photo Supreme is installed. Will that work and will I be able to install its icon on the PS desktop?
HCS
Re: Editor on external computer
Post by HCS » 27 Mar 15 19:28
Stephen wrote:I want to use an editor (Capture One) which I will install on an external computer running a more recent OS than the one running on the computer where Photo Supreme is installed. Will that work and will I be able to install its icon on the PS desktop?
I'd like to be surprised to see that this would work, but i'm pretty certain the program needs to be on the same client as PSU from which you want to start that external program.
Post by Stephen » 27 Mar 15 20:04
Hmm, OK. So if that does not work (the other computer - a mini mac - will be purchased solely for this task) do you think that I could sync the PSU database/installation between both computers?
