Should PersonInImage be written to all versions?
Post by vlad » 17 Dec 14 23:40
For labels under People, I have noticed that the PersonInImage field is written only to the main version. Is this intentional or not? (I suspect a bug but I'm not sure.)
Re: Should PersonInImage be written to all versions?
Post by Mke » 18 Dec 14 18:05
Well noticed. I see that 'event' is also only being written to the main image too, so looks like a more generalised problem. I've raised a bug report on Mantis (#2737).
LifeIsLong
Post by LifeIsLong » 18 Dec 14 22:47
Isnt this similar to the "areas tags in versions" issue brought up recently (http://forum.idimager.com/viewtopic.php ... as+version) ? Wouldnt it depend on how the version was cropped, which means PSU would have to guess?
Post by vlad » 18 Dec 14 23:38
Hmm, are you saying that a Person In Image may actually be left out of a version? In theory, that could be indeed the case - but, then, the same argument may apply to a label, while the current implementation is that all labels (including person and event labels/keywords) get automatically cascaded. I would therefore expect label mappings to apply to all versions too. (Btw, I think that's already the case with keywords, custom mappings and applied profiles.)
Post by Mke » 18 Dec 14 23:42
LifeIsLong wrote:Isnt this similar to the "areas tags in versions" issue brought up recently (http://forum.idimager.com/viewtopic.php ... as+version) ? Wouldnt it depend on how the version was cropped, which means PSU would have to guess?
I can see where you're coming from, but no. The labels apply to the image as a whole, and so the XMP so should also be written to all versions (though it's true that a version could have cropped out a person entirely).
Area tags are saying that a particular part of an image corresponds to a particular person; a crop in this case could easily mean that the person no longer aligns with the part of the image describing them, as per the mocked-up image below. Though in theory the software could be enhanced to 'look' at the two images and work out where to reposition the tags on the cropped version.
