Default program for import when inserting a memory card
RBrianTaylor
Post by RBrianTaylor » 14 Nov 14 18:30
Hello, I'm a newbie to Photo Supreme, and I was wondering if someone could help me out. I'm testing the trial version of Photo Supreme (hoping that I can replace Lightroom), and I can't figure out how I can tell my Windows 7 computer to automatically open Photo Supreme to import photos every time I insert a memory card with photos on it. I've found the Control Panel area where I can set the default program to "choose what happens when you insert each type of media or device", but in the "Pictures" section, I do not have a choice to select Photo Supreme among the various programs I have installed on my computer. Is there a way around this?
Re: Default program for import when inserting a memory card
Post by Mke » 15 Nov 14 15:40
Hi - and welcome to the forum!
It looks as though that isn't a standard feature, however I've tracked down some software (http://defaultprogramseditor.com/) and instructions (http://www.7tutorials.com/customize-fil ... ams-editor - scroll down to "How to Manage AutoPlay Settings") that should, it would appear, allow you to set it up.
RBrianTaylor
Post by RBrianTaylor » 18 Nov 14 1:19
Thanks! While not quite as elegant as Lightroom (which automatically starts up in the import photos screen when inserting a memory card into my computer), at least the correct program opens after I made the mods you assisted me with. Thanks!
Maybe IDimager will see fit to add this native memory card support in future versions (it seems like this would be a basic feature, but maybe other people's workflows are different than mine).
Post by jstartin » 18 Nov 14 10:53
If Photo Supreme is running first, then inserting a card should launch import automatically.
DirkS
Post by DirkS » 18 Nov 14 11:34
jstartin wrote:If Photo Supreme is running first, then inserting a card should launch import automatically.
IIRC you get a 'never ask again' option, so if it does not happen a reset of the 'do not ask again' questions (Help menu) should activate it again.
Gr.
Dirk.
