Apply to Full Version Set question
User avatar
OldRadioGuy
Post by OldRadioGuy » 07 Sep 14 22:38
I have an old external editor -- Sagelight -- which I use on a problem image occasionally. It has a bug that was never fixed. Sagelight strips all exif data from its processed images (saved to TIF or JPG).
In Photo Supreme, I've tried going to another image in the version set in which the Sagelight version appears and using "Apply to full version set" to restore the missing exif data, but that doesn't work. Is there a function available to do this that I've overlooked.
Thanks in advance for your answer.
Bob
macOS High Sierra; 27-inch iMac, Retina 5K; Photo Supreme 4; DxO PhotoLab 2; ON1 Photo RAW 2019; Alien Skin ExposureX4; Affinity Photo 1.6.7; PhotoLine
