Displaying issue on thumbnail info.
lulumine
Post by lulumine » 22 Mar 14 1:38
After applying scripts found on the forum to customize display of thumbnail info (scripts from andy@roundup.dam & david grundy), I notice today the 2 following issues on thumbnail displaying :
1. upper left : the ribbon showing the place holder's icons is oversteping the thumbnail frame (I've tried different zoom ratio without any improvement)
2. down : the bottom of all characters from each line seems "cropped" by the following line (depending on the zoom ratio -threshold around ~100%-)
I don't remember if it was the case before applying these scripts...I use PSU v2.0.4.1025 x64
Olivier PSU v2.2.5.1044 / Win7x64 - Intel core i7 950@3,7GHz-RAM6Mo
Re: Displaying issue on thumbnail info.
Post by Hert » 22 Mar 14 6:50
About point 2; you're using an old version of that script. I remember that the author posted an update to fix that.
David Grundy
Post by David Grundy » 22 Mar 14 9:01
The (*ahem .. modest cough) author's update here or here says:
(Note 2014-02-03 for PSu v2, there is no need for the vertical offset specified in this and some other scripts. Remove unwanted occurences of <ind y="2"> and </ind> from the code to fix the vertical position of the graphic elements.)
lulumine
Post by lulumine » 23 Mar 14 14:37
Thank you very much, David, to let me go deeper in posts/threads of the forum : It works now...
Do you know something about the ribbon issue ?
David Grundy
Post by David Grundy » 05 Apr 14 14:32
Unfortunately I can't help with the ribbon issue as I haven't seen this one. (Although, I should add that my version of PSu is not currently the latest available, due to being too busy to think much about photos in the last little while.)
lulumine
Post by lulumine » 05 Apr 14 15:06
Hi David,
Ribbon issue is adressed in ticket 1951 (open)
