is there a loupe shortcut?
mantras
Post by mantras » 01 Mar 14 9:50
Hi
may i know if there is a loupe shotcut?
thanls
Preston B
Re: is there a loupe shortcut?
Post by Preston B » 01 Mar 14 16:59
I did not see a short cut in the Keyboard Shortcuts for PSu topic.
You might want to post a feature request at Mantis in case I missed it.
-p
Preston Birdwell
Columbia, CA
Post by tstoddard » 01 Mar 14 22:49
I just discovered that Alt + Z works for me to open the loupe.
Also, this may be a little off topic but in trying to see if I could find a hidden shortcut to open the loupe, I noticed that the "s" key causes images to appear sharpened and then it toggles that sharpening on and off. I don't see that listed in the Keyboard Shortcuts topic. Can anyone tell me exactly what that shortcut is doing? I'm guessing its just adding some degree of sharpening but I don't know how much.
Post by Hert » 02 Mar 14 9:18
Maybe the [s] key toggles the Options-Show Sharpened setting? I don't know the level of sharpening, but in expect it to be around 20 to 30. I never understood why people use such a setting.
UPDATE; I've looked it up and [s] indeed toggles the Show Sharpened setting, though it doesn't set the checkmark. This shortcut is removed in the next update. The designated shortcut for "Show Sharpened" is Ctrl/Cmd+Q
I've now updated the shortcuts list and extended the list of shortcuts.
In the next update [L] is added as a shortcut to toggle the Loupe
mantras
Post by mantras » 02 Mar 14 17:48
tstoddard wrote:I just discovered that Alt + Z works for me to open the loupe.
hi
thanks ! how did you find it?
for now i will use alt+z
Post by Hert » 02 Mar 14 18:11
Based on this topic I played with the Loupe for a while and made some significant improvements for the next 1024 build.
mantras
Post by mantras » 02 Mar 14 18:41
IDimager wrote:Based on this topic I played with the Loupe for a while and made some significant improvements for the next 1024 build.
In addition, the Loupe will default to a zoom factor to match a 100% view of the original bitmap.
hi
is your eye?
really a great improvement!
but about the loupe shape :) don't you find it a bit bulky :D
Post by Hert » 02 Mar 14 18:46
Yes, that's my eye haha
Replacing the loupe graphic is more work than you may think. Not very important for now.
