fanuelsen
Post
by fanuelsen » 16 Feb 14 11:27
Hi everyone.
I have question for you. If you buy the Photosupreme SQL version, and install it on a Windows server with MS SQL on it. Will Mac users be able to connect to the sql server? Or only windows clients? The reason I ask is because we use both Mac and Windows here, and that would be realy nice to have a DAM solution that works on both platform with a shared library.
Thanks for anyhelp.
Post
by Hert » 16 Feb 14 14:33
Photo Supreme for SQLServer can use both Windows as Mac clients.
The Microsoft SQLServer database should be installed on a Windows Server/computer but both Mac as Windows clients can connect to it.
Hope that helps
Feature requests, change suggestions, or bugs can be logged in the
ticketing system
fanuelsen
Post
by fanuelsen » 16 Feb 14 19:00
Thank you very much. That was the answer i was hoping for! =)
Just out of curiosity from an IT Administrator point of view, are you planning on a Linux/BSD based server in the future?
Post
by Hert » 17 Feb 14 5:37
Sorry, but I don't make announcements about what will or won't be included in future versions. PSU uses Microsoft SQLServer as its RDBMS and SQLServer runs on Windows only.
ticketing system
