Moving Mirror Location
I am challenged with the management of applying mirroring. Is it only possible to mirror images when ingesting includes copying images to a new location or is there an option to mirror if I only import the images into the catalog? Once mirrored what is the process of moving the mirrored image location? How does Photo supreme track the mirrored image or does it?
Re: Moving Mirror Location
Also if I have imported images and not applied mirroring how would one do so later?
Mirroring is used to create a secondary backup of the files that you ingest. Those files are not part of the catalog.
If you mean that you just want to move or copy files then you can do that in FOLDERS
Hope that helps
Hope that helps
