Filter by orientation?
Post by weidmic » 09 Feb 14 22:49
Is there a way to filter by orientation - Landscape / Portrait?
PSUServer 6.x, PostgreSQL 12.x
Re: Filter by orientation?
Post by Hert » 09 Feb 14 22:56
The "filter by macro command" script should be able to help
Post by weidmic » 09 Feb 14 22:58
can you explain how?
Post by Hert » 09 Feb 14 23:03
Filter on
%xmp:tiff:Orientation
Possible values can be found for tag 0x112 (orientation):
http://www.sno.phy.queensu.ca/~phil/exi ... /EXIF.html
Typically it will be value 1, 6, or 8
Post by weidmic » 09 Feb 14 23:10
Thanks, that works...
Too bad those filters can't be saved.
Regards,
Post by Hert » 09 Feb 14 23:12
You can adapt the script and build in a save feature.
