should the info display visualize the adobe rgb?
mantras
Post by mantras » 09 Feb 14 10:21
hi
i have almost my photos taken in raw and jpg in adobe rgb
but i did notice that the info display visualize always sRGB
while bridge for example display the correct color space
in the info panel , i create a new field exif:ColorSpace and it gives me 1
photosupreme 64bit 2.0.2.1020 ,w7 64bit
Bridge cs6
and photoshop opens this file in adobe rgb
is it normal?
Re: should the info display visualize the adobe rgb?
Post by Hert » 09 Feb 14 10:24
Can you send me a sample file?
Exif:colorspace value 1 means that the file is sRGB. Maybe your metadata is inconsistent and your XMP contains something else. You van check that yourself by adding %xmp:Exif:colorspace
mantras
Post by mantras » 09 Feb 14 15:30
IDimager wrote:Can you send me a sample file?
yes i sent it via email
thanks Hert
Post by Hert » 09 Feb 14 19:48
I've looked at the file and it contains conflicting metadata. The metadata tags for ColorSpace all say that this is a sRGB image. This is also reported a s sRGB color space by ExifTool.
But...the file contains an embedded color profile which is the AdobeRGB profile.
PSU reads metadata to detect what the color space of the file is and hence reports sRGB, as that is what's in the metadata
mantras
Post by mantras » 10 Feb 14 8:37
thanks Hert
