Scripting Documentation
lauff
Post by lauff » 26 Dec 13 18:35
I want to start developing some scripts, but I can't find a complete documentation.
What I found is the "IDimager.chm" but this doesn't look complete (at least not for Photo Supreme).
Yes, I can of course browse existing samples, but this is neither really convenient, nor complete.
e.g. There is no information about "Progress"
  Progress.UseProgress;
  Progress.Pos := 0;
  Progress.Show;
  Progress.ProgressText := 'Starting ...';
For the example above I can't figure out why "Progress.UseProgress" no longer works in Photo Supreme (as I copied the code from the IdImager repository, I guess it worked before in IdImager).
What do you use / what can you recommend?
Warm regards,
Markus
P.S. BTW, even the information in "IDimager.chm" is terribly documented.
Re: Scripting Documentation
Post by Hert » 26 Dec 13 20:42
Hello Markus,
Progress.UseProgress is not available in PSU. PSU uses a different progress module compared to IDI and in PSU the "UseProgress" property is irrelevant...there's always progress; it's a progress component after all ;) If you want to convert IDI scripts to PSU then you should remove this line.
lauff
Post by lauff » 28 Dec 13 11:58
Thanks for the quick help, unfortunately I got some more questions...
How can you show the "cancel button" in the progress, so the script can be cancelled?
How can I move a TCatalogItemProp to another parent?
Is there any way to display structure of an object / available functions (e.g. while debugging or code completion)?
Warm regards,
Markus
Post by Hert » 28 Dec 13 12:11
Here's a sample for Progress:
var
  i: Integer;
begin
  Progress.Caption := 'My Caption Title';
  Progress.Pos := 0;
  Progress.Max := 100;
  Progress.CanCancel := True;
  Progress.Show;
  for i := 0 to 100 do
  begin
    Progress.Pos := i;
    Progress.ProgressText := 'You''re now at position: ' + IntToStr(i);
    if Progress.Cancel then
      break;
    // do your operations here...
    Sleep(50);
  end;
    Say ('Cancelled');
  Progress.Hide;
end;
See Catalog.StorePropToDatabase (AProp: TCatalogItemProp; AParentGUID: String; WithSubs: Boolean = True)
No, there's no debugging or code completion. Available functions and properties can be found in the CHM
