may i create a portable version?
mantras
Post by mantras » 08 Jul 13 16:09
Hi
sometime i would love to have my photo supreme in a usb stick full portable
is enough create a shortcut with the command line
-portable
thanks
Re: may i create a portable version?
Post by Hert » 09 Jul 13 10:33
It's not officially available, but have you tried?
mantras
Post by mantras » 09 Jul 13 15:40
IDimager wrote:It's not officially available, but have you tried?
yes
don't sure it works
i would like to use at work without leaving registry tracks or files
mantras
Post by mantras » 10 Jul 13 6:10
can you please confirm ? it's full portable
i would appreciate it a lot
Post by Hert » 10 Jul 13 6:14
I did confirm. It's not officially supported
Have you tried?!!
mantras
Post by mantras » 11 Jul 13 7:17
IDimager wrote:I did confirm. It's not officially supported
Have you tried?!!
yes seems to work i i mean full portable
but i should test on a different pc ,because i have photo supreme installaed on my desktop and laptop both with windows 7
by the way have a full portable version is a great thing , hope the command line will not disabled in the future updates
mantras
Post by mantras » 22 Jul 13 7:05
Have you tried?!!
hi
i gave a deep test under w7 and it's not full portable
would be great to have a full portable , for example i bought a very tiny slim usb hard disk usb 3 , have it i can use at work or in other pc without leaving files and registry keyleft
thanks
