Need some help with milliseconds !
stevehughes
Post by stevehughes » 20 Jun 13 0:04
Nice vague subject to attract interest :D
I've been playing around with renaming rules for a while with the aim of getting something that I can guarantee to be unique across my whole collection and (hopefully) remain unique if I add in third party files. For the last few years with my D50 I have used the rule:
SGH_%yyyy-%mm-%dd_%hh%nn%ss.%FileExtension
This worked most of the time although I would occasionally get a (001) appended. The burst capability of the D50 in RAW was limited so I rarely produced multiple shots per second.
Having added a D7100 I regularly shoots bursts and also need to deal with results from a 'two camera shoot', So I figured I would add fractional seconds and also the camera model:
SGH_%yyyy-%mm-%dd_%hh%nn%ss.%zzz{mid=1,1}_%exif:Model{word=2}.%FileExtension
This gives, for example:
SGH_2013-06-16_091656.3_D7100.NEF
Note the funny string manipulation of the milliseconds ( I could have used 'left' rather than 'mid' but I was experimenting). The milliseconds is where my problem lies. The NEFs seem to record the fractional part of seconds differently to the derived JPG. For example, for the above image I get the following results from exiftool:
RAW: Date/Time Original : 2013:05:19 09:16:56.30
JPG: Date/Time Original : 2013:05:19 09:16:56.299999232
I want my rename rule to be robust enough that I get the same result when applied to both the NEF and the derived JPG.
Is there some way to get PSU to perform a rounding function so the '.299999232' gets rounded to '.3' ? Then my worries would all disappear.
Regards,
Steve
stevehughes
Re: Need some help with milliseconds !
Post by stevehughes » 20 Jun 13 1:20
Never mind... with a bit more thought I think I got it:
SGH_%yyyy-%mm-%dd_%hh%nn%ss.%zzz{format=%1.0e;left=1}_%exif:Model{word=2}.%FileExtension
Steve
mphillips
Post by mphillips » 20 Jun 13 7:15
Hi Steve
What I have used is the Camera Name plus Year - Month - Day - Plus Shutter Count.
Caters for burst shooting - and I have never had a duplication yet.
Just a different view / idea :-)
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
stevehughes
Post by stevehughes » 20 Jun 13 7:22
That's a rather good idea Mike. Thanks.
mphillips
Post by mphillips » 20 Jun 13 8:13
Hi Steve
My Renaming Rule:
%code
if (AnsiSameText('%exif:Model', 'Nikon D70')) then result := 'D70_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Nikon D40X')) then result := 'D40X_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Nikon D70S')) then result := 'D70S_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Nikon D80')) then result := 'D80_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Nikon D90')) then result := 'D90_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Nikon D200')) then result := 'D200_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Nikon D300')) then result := 'D300_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Nikon D800')) then result := 'D800_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else if (AnsiSameText('%exif:Model', 'Canon EOS 350D DIGITAL')) then result := '350D_%yy%mm%dd_'+AddLeadingChars('%exifmakernote:ShutterCount', '0', 6, False)
else result := '%exif:Model_%yy%mm%dd_'+'%FileNumber';
%/code
.%FileExtension
Regards
MikeP
Mike Phillips
D800, CNX2, Supreme
Post by weidmic » 20 Jun 13 8:26
%yy-%mm-%dd_%exif:Model%code Input := StrTran (Input, 'Nikon D', 'D'); %/code_%exifmakernote:ShutterCount.%FileExtension
one more renaming rule :)
stevehughes
Post by stevehughes » 20 Jun 13 8:31
Thanks Mike,
Even though PSU doesn't do quite everything that I would like, it certainly has renaming by the short-and-curlies !
Steve.
stevehughes
A case of sheer delight !
Post by stevehughes » 22 Jun 13 21:55
Hi Mike,
Your previous post caused the penny to drop, and I finally realised that PSU's scripting is just Delphi code. So I dug out my dusty programming skills from a past life and came up with a renaming rule that will parse the multi-word Model name and drop in a short descriptor for those models I know / care about (basically just choosing which word carries the most useful info). Just posting it here for the benefit of anyone who comes looking for examples.
SGH_%yyyy-%mm-%dd_%hh%nn%ss-%zzz{format=%1.0e;left=1}%code
case '%exif:Model{word=1}' of
   'NIKON', 'Nikon' : result := '_%exif:Model{word=2}'
   'CANON', 'Canon' : result := '_%exif:Model{word=3}'
   'KODAK', 'Kodak' : case '%exif:Model{word=2}' of
                         'EASYSHARE' : result := '_%exif:Model{word=3}'
                          else result := '_%exif:Model{word=2}'
                      end
   'FinePix'        : result := '_%exif:Model{word=2}'
   ''               : result := ''
   else result := '_%exif:Model{word=1}'
end
%/code.%FileExtension
Steve
stevehughes
Post by stevehughes » 22 Jun 13 22:08
Thanks weidmic. Looks to me that renaming rules can be as simple or complex as required.
Level 1 - just pick the required functions from the drop-downs
Level 2 - edit the text and add parameters (which unfortunately I have to refer back to the IDI help for - the PSU help seems very 'thin')
Level 3 - drop in %code and %/code, then write whatever you want !
Love it.
David Grundy
Post by David Grundy » 23 Jun 13 6:19
Hmmm, when I was asking about help for scripting a while ago I never realised we were talking about Delphi; I was wondering how other people seemed to know something about the syntax. I only realised it quite recently. Perhaps a thought for Hert - when scripting is mentioned in the documentation or elsewhere, it may be useful to mention "Delphi".
Anyway, not a language I know anything about and I really have no time to learn!
This doesn't work for me, either for Canon- or Olympus- derived DNG files. I just get literally nothing (no characters in the output file name) from this:
Is this code specific to Nikon?
... David
Post by tstoddard » 23 Jun 13 14:57
David,
I'm not sure about this but I think PSU only supports Nikon and Canon makernotes. I'm not sure why or where I got that impression but I believe makernotes are very proprietary so supporting all makers could get pretty difficult. Perhaps Hert can confirm.
Post by weidmic » 23 Jun 13 20:55
David,
can you share a imagefile, just snap a shot of a wall or whatever?
Regards,
David Grundy
Post by David Grundy » 24 Jun 13 14:19
Happy to share an ORF or a DNG (both have the same result with the renaming rule). As I can't upload such a large file to the forum, is there somewhere I can send it?
Thanks for pursuing this.
... David
Post by weidmic » 24 Jun 13 15:39
David,
there are several free "file sharing" services out there...
I use dropbox a lot.
Regards,
