Refresh a Folder View?
Preston B
Post by Preston B » 31 May 13 0:14
Hi All,
Is there a shortcut key, or menu item to refresh the view of the thumbnails in Folder View? If so, I can't find it.
Let's say I use 'Verify Folder' after I've saved new images to that folder from another application, such as VueScan or Photo Shop.
I run 'Verify Folder' and let PSu process the images.
The only way I can see the new images is by selecting a different folder and then go back to the folder view in which the images were saved.
Is there another way to refresh the view so that my new images will appear without having to select another folder and then go back?
If there's not, I'll add it as a 'feature request' in Mantis.
--P
Preston Birdwell
Columbia, CA
Re: Refresh a Folder View?
Post by jstartin » 31 May 13 8:02
Preston B wrote: If there's not, I'll add it as a 'feature request' in Mantis.
http://bugs.idimager.com/view.php?id=1199 might already cover it :wink:
Preston B
Post by Preston B » 01 Jun 13 0:43
Thanks, Jim! I found the report and voted for it.
--P
Preston Birdwell
Columbia, CA
