is there a script or a way to purge unused keywords?
mantras
Post by mantras » 25 May 13 5:56
Hi
is there a script or a way to purge all the unused keywords from the catalog ?
i imported some photos and after i deleted them , but in the catalog i have lots of unused keywords
delete them manually it's boring because there a lot
i would be really great a script or (i don't know if there is a way ) to remove/purge all the un-used keyword with 1 click
a good dam software should have this feature
thanks
DirkS
Re: is there a script or a way to purge unused keywords?
Post by DirkS » 25 May 13 10:41
I assume you mean Catalog Labels?
You can try Find empty catalog labels
I think it will work with PSu, but I have not tried it myself.
Gr.
Dirk.
mantras
Post by mantras » 25 May 13 15:42
hi
yes
to run the script should i tools -> scripter -> load the script -> run script ,right ?
thanks Dirk
DirkS
Post by DirkS » 26 May 13 23:26
mantras,
Did a bit of testing and the repo script does not work, for various reasons. Most important one is that it looks for *all* empty labels, not just in the Keywords / Miscellaneous category.
So I made a q&d script which should work (did a quick test and it didn't do anything horrible with my data :wink: ).
It does not ask any questions, but will delete all the entries in 'Miscellaneous' that have no images attached.
Download the attached file and then open and run it in the scripter.
HTH
Dirk.
delemptykeywords.psc
(1.04 KiB) Downloaded 100 times
mantras
Post by mantras » 27 May 13 6:18
DirkS wrote:mantras,
HTH
Dirk.
Hi Dirk
thank you so much!
