Hello
here i am again
what happened to drag select in the image view window or any of the view settings available as it is now a pain in the rear to select multiply images as im forced to use shift or ctrl for more then one image or is my version of photo supreme broken im using 1.0.8.67
thanks
chris
What Happened Too.... Drag Select
Re: What Happened Too.... Drag Select
Chris, this is added to the next update (build 68 which is not available yet)
Thank you
Thank you
