problem with offline dvd media
artphotopro
Post by artphotopro » 24 Oct 12 16:12
hello, im not sure if this is a bug or im just not using the program right but when i used file-import single image from a dvd i then removed the dvd from the pc and photo supreme showed it as offline in the catalog view but when i tried to delete the folder it would not allow it even if the dvd was in the drive and the folder was online i found i had to relocate the dvd folder to an empty folder on my hdd and then it would allow me to delete folder and contents, am i doing something wrong or cant photo supreme remove/delete offline media from its database.
thx
chris
