Batcher Versioning Request
Post by Mike Buckley » 10 Oct 12 14:02
The Batcher allows us to automatically assign the newly created version as a member of a version set. However, it does not allow us to make the newly created version the Main Version. If that were made possible, that would satisfy all of my needs with regard to making version sets; no Version Detection Wizard or similarly functioning batch module would be needed.
The practical application is that I always use the Batcher to create "Large JPEG" and "Web JPEG" versions from my RAW versions. In IDimager V5, I then use the Version Detection Wizard to version the three images though making the "Large JPEG" version as my Main Version.
If there is some other way to meet my batch versioning needs using Supreme, I'm eager to learn about it.
