Add meta data to images on import
Alfons
Post by Alfons » 06 Oct 12 17:52
How can I add meta data stored in a profile to images on the import as it was possible with IDI? I did not find this option in the import module.
Thanks and best regards,
Alfons
gcoupe
Re: Add meta data to images on import
Post by gcoupe » 06 Oct 12 20:04
Check the "Apply import detail profile". It allows you the same flexibility as with IDI.
Geoff Coupe
