catalog counts hard to view
andrew.heard
Post by andrew.heard » 25 Sep 12 1:18
Does anyone else find the item counts to the right in the catalog pane incredibly hard to see - being dark gray on light gray. I am running Windows XP, maybe in Vista, W7 or Mac it is slightly better?
screen capture
screen capture
2012-09-25 10-14-32_Photo Supreme _ database idimager.jpg (14.54 KiB) Viewed 1658 times
gcoupe
Re: catalog counts hard to view
Post by gcoupe » 25 Sep 12 7:59
Yes, me too! My eyes are not what they were, and I'm running on Windows 8.
I see that this issue has already been reported in the bug-tracking system some time ago. It got marked as "resolved" because the contrast was improved. However, I don't think it has been improved far enough, so I've raised it as a new issue in the system.
Geoff Coupe
andrew.heard
Post by andrew.heard » 25 Sep 12 10:37
Hi Geoff - do your counts look like in my screen capture? That's very low contrast. It would be handy if the bug tracking system indicated which PS version the fix was made in.
gcoupe
Post by gcoupe » 25 Sep 12 10:52
Andrew, yes, my screen looks the same. It was originally marked as resolved in issue #43, but I've just raised it again as issue #1111. Search for "contrast" in Mantis,. and you'll find them.
Geoff Coupe
