Drag and drop thumbnails to another program
Will it be possible to drag image thumbnails from PS to to other programs that support this? Is there another way of opening some images in another program that were selected in PS?
Ilan
Ilan
Re: Drag and drop thumbnails to another program
Hi Ilan
Supreme doesn't support drag and drop.
To pass image / images to another program - define the programs under Preferences - Other Settings (Supreme may have already found some for you)
Then Highlight the images to pass and click on the icon of the program in the top right of top bar or Supreme. *you can also use Shift and the relevant Number to access the program quickly
Hope this helps
Regards
MikeP
Hope this helps
Regards
MikeP
Thank you MikeP. This helps for some situations but it is not a full substitute for the drag-and-drop functionality.
Ilan
Ilan
This is implemented in the next update. However... you need to Alt+Drag to be able to drag outside of the application.
This only works on Windows.
We didn't enable drag/drop to the Operating System before because we haven't implemented this on MacOS and I did't want to deploy a different feature set between Mac and Windows.
But based on all the sentiments about missing D&D we've now enabled it for Windows. This will only work on Windows though. Mac users will get this feature in a future update.
Thanks Hert
Thanks a lot.
Still didn't work with QuarkXpress, but nevermind.
You did alt drag? If it doesn't work with quarkxpress then that tool probably doesn't support drop files from the OS. This is an OS feature triggered from the application. Another possibility is that that tool doesn't accept copy-drop types.Menace wrote:Still didn't work with QuarkXpress, but nevermind.
Edit; while giving this a few more secs thought i think the latter is the case. If this works with IDI (mwhich uses link type by default) the this is for sure the cause
Hi Hert
It also doesn't work for Glamour and Splash - and they do accept D'nD from the OS. But they also don't seem to accept D'nD from V5 either.
MikeP
MikeP
It didn't work with V5 either. I wrote this in one other thread I guess. With IMatch and Daminion I haven't a problem.
http://forum.idimager.com/viewtopic.php ... ess#p94154
But, how I said, never mind. I guess I am the only one, who need QuarkXpress and I'll changer (because of workflow and filemanager) the software.
