Portfolios
JimiV
Portfolios
Post by JimiV » 19 Sep 12 10:24
OK, so maybe I can use portfolios as I was using Virtual Collections. But am I missing something about workflow with them?
I have TOC and Pending Portfolios imported from IDI.
I marked them as favorites
I'm in a folder and want to add an image to the TOC portfolio. It seems I can't just drag and drop that image on the favorite?
So I have to:
1. add image to Image Basket
2. change catalog view to 'by Portfolio'
3. then drag image into the correct portfolio?
4. then return to folder of images I was viewing.
Am I correct in thinking that a simple drag and drop has been replaced by a 4 step process?
IDimager Pro 5x
Bibble Pro 5x
PhotoMechanic, Lightroom 3x
Canon stuff
mphillips
Re: Portfolios
Post by mphillips » 19 Sep 12 10:35
Hi JimV
Yes - you are correct
Regards
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
JimiV
Re: Portfolios
Post by JimiV » 19 Sep 12 11:22
You know, I like a lot some of what I see in PSU. If they had added those features to IDI, it would have rocked.
But I simply can not believe they took the most powerful DAM product out there and killed half the stuff that made it unique. I'm not happy at all about this.
Have I not found support for Workspaces, or is that gone? Dual Monitors?
IDimager Pro 5x
Bibble Pro 5x
Canon stuff
george
Re: Portfolios
Post by george » 20 Sep 12 0:27
JimiV wrote:Have I not found support for Workspaces, or is that gone? Dual Monitors?
Both gone, sadly.
George
rNeil
Re: Portfolios
Post by rNeil » 20 Sep 12 1:08
No Workspaces, no multiple monitors, no file management, versioning seriously reduced, labeling capability seriously reduced, a number of drag & drop actions turned into 4 or 5 manual step tasks ... yea, sadly ...
Neil
R Neil Haugen
rNeilPhotog.com
MyPhotoMentor.com
Haugensgalleri.com
andy@damroundup.com
Re: Portfolios
Post by andy@damroundup.com » 20 Sep 12 1:28
I didn't realize how dependent I had become on the second monitor until it was no longer available.. perhaps something that will return down the road as I feel it is quite useful.
Re: Portfolios
Post by Hert » 20 Sep 12 1:39
What made you conclude that?
Jesperben
Re: Portfolios
Post by Jesperben » 20 Sep 12 7:52
I dont understand your remark on monitors? It seems to use both my monitors?
Re: Portfolios
Post by Hert » 20 Sep 12 10:04
Jesperben wrote:I dont understand your remark on monitors? It seems to use both my monitors?
It will use a dual monitor setup when the monitors are configured as a single monitor (stretched). But you can't use two monitors when they are configured as two individual monitors.
Re: Portfolios
Post by tstoddard » 20 Sep 12 12:22
I would agree, unless I'm missing something. I have not found a way to work with multiple label as I could in IDimager. I can't assign multiple labels or edit multiple labels. At times, this functionality was very useful and saved a lot of time.
