Those Little Flag Images
tvandawalker
Post by tvandawalker » 25 Jun 12 18:11
I deleted a few States and now want to add one back. Does anyone know where those little flag images are stored?
Tim
DirkS
Re: Those Little Flag Images
Post by DirkS » 25 Jun 12 19:53
Tim,
As far as IDI is concerned: in the catalog (IIRC in the same record as the Catalog Label itself). If you delete a Cat label the image will be deleted with it...
Gr.
Dirk.
Post by Hert » 25 Jun 12 20:44
Tim, you can add an icon to a catalog label by right clicking on the thumb area in frn of the catalog label name.
Is that what you're looking for?
tvandawalker
Post by tvandawalker » 25 Jun 12 21:47
I knew you could add your own image to the catalog item. I was wondering were on the system I could find the flag images.
Tim
Post by Hert » 25 Jun 12 21:53
Aah, in that case Dirk is spot on. The images are stored in the catalog database as part of a catalog label's details.
Lars
Post by Lars » 26 Jun 12 5:09
...if you create a new database they will all be back...
W7/64bit, IDimager V5 ProSL
tvandawalker
Post by tvandawalker » 26 Jun 12 14:14
Thanks Guys,
I don't think it's worth recreating the database just to get the flag image back, I'll just use something else.
Post by Hert » 26 Jun 12 14:18
One tip; if you visit a site with flag icons then you can quickly assign them to your catalog labels. Just right click in Safari/Firefox/... and copy the image to the clipboard. Then in Photo Supreme, right click on the image area and paste the image from the clipboard.
mphillips
Post by mphillips » 26 Jun 12 14:59
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
