French Translation & bugs
Rikly
Post by Rikly » 25 Jun 12 14:29
Setting the french language in 'Preference' is catastrophic. Some menus stays in english, other in Dutch and the specials characters like 'é', 'à' or 'ç' are displaying as '?'. I hope a better translation in the next update. I found also some little bugs (sort in import) only possible to delete one picture at time. A little to expensive for possibilities and bugs.
Lars
Re: French Translation & bugs
Post by Lars » 25 Jun 12 16:03
Rikly wrote:only possible to delete one picture at time
Should be possible to delete as many as you like - Did you select more than one image? (Selected thumbnails must have brown background - not to be confused with the white-on-green down-arrows)
W7/64bit, IDimager V5 ProSL
Rikly
Post by Rikly » 25 Jun 12 18:28
Yes, I selected 2 pictures, and when I do right click, The dialogue box says '1 image' and he deselect the second picture.
DirkS
Post by DirkS » 25 Jun 12 19:59
Not sure what you mean here.
* You don't explain what's the problem with 'sort in import'
* delete one picture at a time: during the import review or during 'normal' operation in the Catalog Viewer?
Bugs don't get solved automagically and to solve them the developers really need a good description of the problem(s)...
Gr.
Dirk.
Post by Hert » 25 Jun 12 21:06
Hello and a warm welcome to the IDimager forums.
There are no translations for PhotoSupreme; it is only available in English; as is also stated in the Mac App Store.
That drop down you used was added for the future but should have been invisible in the final version. The drop down will be removed in the first update. Thank you for reporting this.
Rikly
Post by Rikly » 26 Jun 12 9:14
Selecting more than 1 pictures and clicking right mouse button to delete, deselect 1 image.
Selecting more than 1 pictures and pressing the Del key on the keyboard works !
When importing a selected folder don't import the image in alphabetic name file order.
When deleting images, the counter not go down, until you close and restart the software.
Have a nice day.
Post by Hert » 26 Jun 12 12:56
Hi Rikly,
Rikly wrote:Selecting more than 1 pictures and clicking right mouse button to delete, deselect 1 image.
I don't see that here. If I select multiple images, then right click *on a selected image" then the selection stays active. I do see the behavior that you describe when I have a series selected and then right click on an *unselected* thumbnail. But that is the intended behavior.
That's great.
This is multi threaded software, meaning that multiple files are being imported at the same time.
I don't see this either. When I delete a thumbnail then the counters in the left side catalog explorer and the total number at the top does decrement. Hope you can provide some additional information for this.
Thank you for your input
Rikly
Post by Rikly » 27 Jun 12 6:39
Here is a little screen capture to see the selection:
I try to send two files. One (.mov) is not allowed the second (.zip 3.5 Mb) is to big.
Ok. Close the subject.
Regards.
