Display Headline
Larry56
Display Headline
Post by Larry56 » 31 May 12 14:54
Is there a way to display the Headline under the thumbnail? I can't find any settings for additional display options.
Larry
Re: Display Headline
Post by Hert » 31 May 12 14:57
Find custom thumb options in the View button
dickl
Post by dickl » 01 Jun 12 1:55
Larry56 wrote:Is there a way to display the Headline under the thumbnail? I can't find any settings for additional display options.
Larry
Yes indeed. This is the custom option I use...
<FONT size="7">ISO%exif:ISOSpeedRatings %exif:FNumber %exif:ExposureTime %ImageFileSizeShort<br>%CatalogLabelList</FONT>
Copied from my PC version of Idimager.
Use the down arrow under 'Custom Thumb info' in the menu item on the right "View" to choose the info you would like to display...
I believe the variable for Image description is %ImageDescription
and Headline should be %xmp:photoshop:Headline
Dick
Larry56
Post by Larry56 » 02 Jun 12 4:28
Sorry, I must be blind.
I can't find any setting options for custom thumbnail and the only View is to the right of Filter and that only gives me options of full screen or embedded. No down arrow at all.
I'm running v 1.0.0.44.
Thanks for the help.
Larry
Lars
Post by Lars » 02 Jun 12 10:03
Larry56 wrote: No down arrow at all.
Does this help :
W7/64bit, IDimager V5 ProSL
Larry56
Post by Larry56 » 02 Jun 12 15:03
Thanks Lars, yes.
I had my style set to framed and now I see I need to change to normal to have the custom thumb option.
Larry
