Can't register to report a "bug"
HvTFoto
Post by HvTFoto » 17 Apr 12 19:35
Since I got no reply/answer to my question on how to rotate thumbnails I thought that I should put the question to the support team. Tries to register but without success as the code that is to be entered to validate that I'm not spamming isn't there (replaced by a ?).
HvTFoto
Re: Can't register to report a "bug"
Post by HvTFoto » 18 Apr 12 10:20
Today I tried to register from a windows computer so that I could report what I see as a bug. The problem persists, i.e. impossible to register!
Post by Hert » 18 Apr 12 14:38
I've disabled the captcha now
HvTFoto
Post by HvTFoto » 18 Apr 12 14:53
After successfully registered I ran into the next problem. Can't report as I can't get passed the "project" tab. The project tab is empty and I have to select a project before I can proceed. As I can't report the "bug" I kindly ask you to pass the below question to the support team.
"When working on a picture the rotate works only after I'm done with the picture (if I pick a different photo from the same folder the rotate does not show on the thumbnail), goes back to the folder and pick a different folder (I'm then asked if I want to apply the changes). Is there a way around this, i.e. to have rotate work directly on thumbnails and to have rotate work immediately when working on the picture?"
//Hans
Post by weidmic » 18 Apr 12 15:10
Hans,
You need to write Hert a PM with your username and then he can add you to the project...
HTH
Post by Hert » 18 Apr 12 15:12
Already added.
HvTFoto
Post by HvTFoto » 18 Apr 12 15:34
My issue has now been reported as a "bug".
//Hans
