Some common metadata of jpg does not display after ingest
pgerrish
Post by pgerrish » 03 Mar 12 22:52
When first jpg images (50 in number) have been ingested the Title and Description (2 Metadata fields with the multi language drop) do not display in metadata details for those images- entries shows only two brackets [] . The headline and keywords display OK. The file info viewed in Mac Finder displays the Title, headline and Description correctly and the Title can also be displayed in iPhoto so the jpg file is OK (Files were copied from PC where I use IDI and Metadata displays fine on PC).
One mutil language entry already does show as default but has not been populated. If it requires something else to be done prior to ingesting the user needs to be prompted and guided as these are 2 common Metadata fields used.
Paul
OS Mac Snow Leopard
Re: Some common metadata of jpg does not display after inges
Post by Hert » 03 Mar 12 22:54
Hi Paul,
I am aware of this issue. It is now on top of the priority list.
