Image Preview Update
frith
Post by frith » 16 Feb 12 15:36
Once you have ingested an image file into IDimagerNE, is there a way to update the preview image. For example, if you have ingested an image and then edit it in a program other than IDImageNE and want to update the preview image in IDimagerNE, can you do it? I tried to "re-ingest" the image but it was not updated (likely because as far as IDImagerNE is concerned the image was already in the catalog so there was no action required). I am not sure if many people would find this useful, but for me, I want to use IDimagerNE as my image file management solution, with the ability to do edits within IDImagerNE when needed (often) - but at the same have the flexibility that if I update a file with say Aperture or CaptureNX, the preview image in IDImagerNE can be updated to reflect the edits. Maybe this is asking for too much, but if you don't ask....
Frith
mphillips
Re: Image Preview Update
Post by mphillips » 16 Feb 12 15:59
Hi Frith
Try and F8 (Function 8 ) to update the thumbnail and preview.
Idimager should pick up the changes automatically (as it does in V5 - Windows) but its not working in INE yet.
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
