making removing files clearer
pakunoda
Post by pakunoda » 16 May 09 12:51
Suggestion,
when you remove an image, a warning arises. If the image is selected from media explorer, the warning is easy to understand, remove = delete file.
But when you are exploring your labels, remove = remove from database, and you can choose to keep the file (by default).
I don't know about other users, but I found it confusing during my early days of use; so I suggest adding a line in the warning to remind the user that he is working in "labeling" mode or "browsing" mode.
doug_w
Re: making removing files clearer
Post by doug_w » 22 Jul 09 0:33
I agree that the delete dialogue can be confusing. Hopefully something is in the works for v 5.
doug
photography.dougwieringa.com
Post by weidmic » 22 Jul 09 0:50
Hi Doug and pakunoda,
I think the new delete dialog for V5 is no longer confusing and will please you both :wink:
Cheers
Post by Hert » 22 Jul 09 2:24
Hi Doug
Michael is right... The delete dialog is completely redone for v5 and the del and ctrl+del options are integrated into one.
