Duplicate copies of images in Catalog
neilmwhite
Post by neilmwhite » 14 Feb 13 14:39
When I select images using keywords or labels, there are some where the resulting set displays 2 or sometimes 3 copies of the same image but each with a different set of linked labels.
I know that by deleting the label and then re-importing data from the xmp sidecars that I can get back to something like the correct labelling but it takes quite a lot of effort trying to limit the reimportation to the correct set of images and I then have to reprocess all the keywords into the label structure.
I had thought that using the "search for missing images" query might resolve the problem but that bombs out with an Out of Memory error shortly after starting.
Any other ideas on how to get rid of these extra images in the catalog?
Neil
