IDimager 4.2.0.1 is released
News and Announcements
Locked
Post by Hert » 14 Oct 08 15:09
IDimager 4.2.0.1 is a small maintenance release and has the following additions/improvements over 4.2.0.0:
Fix: Subseconds for Nikon model were not converted to XMP when the XMP is first initialized from the existing Exif values.
Fix: Fixed a bug which prevented copy handler scripts to run in the Downloader
Fix: When the same macro command was used multiple times but with different macro-parameters then only one value would be parsed
Fix: The Options dialog would not display the option categories for some PC-configurations
Fix: The IPTC4XMPExt and PLUS tabs didn't appear on new IDimager installations
Better: The GPS Panel now respects the Theme colors
As with any upgrade it is recommended that you first backup your existing catalog database. You can do that with Tools -> Catalog Manager -> Backup -> Backup to Folder.
Download 4.2.0.1 from the website:
http://www.idimager.com/?page=download
Existing 4.2.0.0 users can use a quick update (unless you need the updated translations). If you are using an earlier version (< 4.2) then you should use the full installation set instead.
To quickly update 4.2.0.0 to 4.2.0.1:
1. Close IDimager
2. Download your version below
3. Copy the downloaded file to your idimager installation folder and overwrite the existing idimager.exe file with the downloaded copy
Pro Desktop: http://www.idimager.com/Trial/Updates/d ... Imager.exe
Pro SQLServer: http://www.idimager.com/Trial/Updates/s ... Imager.exe
Personal: http://www.idimager.com/Trial/Updates/p ... Imager.exe
4. Reapply your license to the newly updated idimager.exe file. See the following thread for assistance:
http://forum.idimager.com/viewtopic.php?f=24&t=5856
DirkS
Re: IDimager 4.2.0.1 is released
Post by DirkS » 14 Oct 08 15:16
Hert,
The data/time of the ProSL executable (for 'easy' update) is earlier (12/10 9:58) than the one that came with the 4.2 full install... :?
Edit: and the version is 4.2.0.0. I downloaded the full install and this contains the correct executable (v4.2.0.1).
Gr.
Dirk.
Post by weidmic » 14 Oct 08 15:46
Dirk
7 Minutes to reply and you have said to me I must have too much time :lol:
Post by Hert » 14 Oct 08 15:49
Dirk,
Somehow the idimager.exe for desktop didn't get copied indeed. This should be fixed now.
DirkS
Post by DirkS » 14 Oct 08 15:56
Hi Michael,
I know... :oops: Better keep my mouth shut in future :mrgreen:
Gr.
Dirk.
Post by weidmic » 14 Oct 08 16:06
Dirk: Better to be addicted to IDimager as to be on drugs :mrgreen:
Cheers
Post by fbungarz » 14 Oct 08 20:42
you fixed it. I just checked. I can read everything in the options box now.
Ready to be installed on the main computer.
Locked
