IDimager 5.0.6.9 maintenance update is available
News and Announcements
Locked
Post by Hert » 15 Jul 10 21:36
Improvements:
- When exporting an IDimager Vocabulary file then the auto-generated labels (like download/import sessions) won't be included
- The maximum number of "recently used items" is raised from 25 to 999
- The Quick Assignment Panel is changed from horizontally to vertically oriented
- The position of the histogram in the Light Table is changed from centered to the upper right corner
- Transfer to SmugMug is implemented as a background process with parallel uploading (3 images)
- Transfer to Facebook is implemented as a background process with parallel uploading (3 images)
- Transfer to ZenFolio is implemented as a background process with parallel uploading (3 images)
- Transfer to PicasaWeb is implemented as a background process with parallel uploading (3 images)
Fixes:
- Template resources in the Web Publisher weren't accessible from within a script (would give a RTE)
- When using color space conversion in the Transfer feature then for Nikon based files, the maker notes are removed from the transfered images as they too contain color space info
- Some characters were parsed out in the Transfer features (email, Facebook, Flickr, etc)
- The numbering offset for %ImageNumber would in some cases start at a wrong offset.
- After editing an area in the Image Viewer then the mouse would behave "odd"
- The Progress Activity counter icon would not reset to 0 unless the Progress Activity Panel was first opened
- Entering Lat/Lon/Alt in the properties of a catalog label would give unpredictable results
- When uploading to Flickr to a new (non-existing photoset) then a new photoset was created for every photo
Re: IDimager 5.0.6.9 maintenance update is available
Post by weidmic » 15 Jul 10 21:55
COOL - works perfectly!
tumirnix
Post by tumirnix » 15 Jul 10 22:17
is there a reason, why this time after the update my installation came up with the question
for the GUI language and the notification to exclude the idi-catalog folder from the
anti virus scans?
It opens like a fresh installation, but the good news is that my catalog was there and also
my "work spaces".
I start my installation with the command line
D:\IDimagerProducts\IDimager\IDimager.exe -a E:\bilder\idi-Daten -regfile E:\bilder\idi-Daten\registry\reg.dat -portable -D E:\bilder\idi-Daten\Catalog\idimager.cat.db
As far as I remember after the last upgrades IDimager started without any change.
Thanks in advance
Martin
Post by Hert » 15 Jul 10 22:23
Hi Martin,
Check the registry folder (-regfile parameter) for the name of the registry file. It may be named differently. This update fixes an issue with the -regfile parameter. Make sure the file name matches by either changing the name of the file in the folder or the -regfile parameter to match the file in the folder.
Post by Hert » 15 Jul 10 22:37
Martin, also read through this topic, which describes the issue: http://forum.idimager.com/viewtopic.php ... ile#p75683
Tonyyd
Post by Tonyyd » 16 Jul 10 23:10
Great update. The Label Assignment Panel is much, much easier to use now that it is sorted in columns, I much prefer this way. Also the increase in the amount of labels previously used is terrific. Today I have been playing around with the label sets.
This software makes it so, so easy to add keywords. There are so many different ways you just have no option but to find one that is suitable for you. Personally I mix and match.
Thank you Hert for all your hard work.
Tony
gcoupe
Post by gcoupe » 18 Jul 10 9:24
Yay! - LAP sorted in columns! Thank you, thank you, thank you!
Geoff Coupe
mphillips
Post by mphillips » 18 Jul 10 12:40
Hi Hert
Has something changed in the Full Screen Viewer for 5.0.6.9.
There is a mega memory leak when using the Full Screen Viewer to browse and rate images.
I will post a video showing in a few minutes. and post in the Bugs Forum.
Regards
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
Post by Mike Buckley » 18 Jul 10 13:14
Hert/IDimager wrote:Improvements:
I would have sworn that I posted this the first day the update was released, but I don't see my post. (I wouldn't want to appear to be unappreciative.) Those two items make a bigger improvement than even I thought they would and I asked for them. Many thanks, Hert!
drewcrew
Post by drewcrew » 18 Jul 10 13:28
Thanks Hert for the update.
I was disappointed that this update and other recent ones haven't fixed the bugs I identify here: http://forum.idimager.com/viewtopic.php?f=15&t=13714
and here: http://forum.idimager.com/viewtopic.php?f=15&t=12526.
Any plans to do so in the near future?
~Nick
Locked
