IDimager 5.0.3 is released (maintenance release)
News and Announcements
Post by Hert » 28 Jan 10 11:19
This version fixes a major bug during the import process. It is highly recommended to upgrade to 5.0.3.
The main changes in this version are:
Improvements:
Added an "Append recipe from file" option to the Recipe Panel of the Image Editor
The active filter is maintained between invocations
You can now drag/drop labels to the content area of a Catalog Label Set; in addition to D&D to the set's caption
Fixes:
When editing images then the edits would not always display correctly when Color Management was switched ON
The settings for a resize in a recipe weren't persistent
Fixed a bug in the sort routines that caused an error when using the ascending/descending sort switch icon while the Random Sort is active
Fixed an issue that caused a file's metadata to be rewritten during import when the option to create folder labels was selected in the Import Dialog
mantra
Re: IDimager 5.0.3 is released (maintenance release)
Post by mantra » 28 Jan 10 12:59
thanks Hert
idimager is the best , spread the word :!: :!:
have a great day
sveto
Post by sveto » 28 Jan 10 13:51
Thanks Hert. One question though: the new option for better quality interpolation in the fullscreen viewer is not in this version, right? I couldn't find it.
Sveto
Win7 64bit
Post by Hert » 28 Jan 10 13:55
Yes, it is but it's a only available with a tweak.
1. Run this little script with F9:
Options.ImageViewerQuality := ivqBest;
2. Then open the Options dialog (Tools -> Options)
3. In the Options dialog, click Apply
Do you notice the difference? If so, do you notice the performance hit?
sveto
Post by sveto » 28 Jan 10 14:14
Unfortunately it doesn't work. After running the script and applying the options, IDI freezes on image opening. I waited for 10 seconds, then killed it in task manager. Tried again, no avail - switched back to good quality. Something is not working. Any ideas why?
Sveto
Win7 64bit
mphillips
Post by mphillips » 28 Jan 10 14:54
Same Here.
But what I also noticed is that with a single image and a frozen grey screen (my image background is normally black) the window resize bar - present when you select multiple images and lighttable them, was visible at the top of my screen.
Regards
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
D800, CNX2, Supreme
markmaus
Post by markmaus » 28 Jan 10 17:51
Dear Hert,
maybe I'm to blind or just stupid ;-), but where can I find the update? The automatic update check in IDimager returns no result and I can't neither find any related download here nor at the main site.
Kind regards
Mark
Post by weidmic » 28 Jan 10 17:57
Mark,
when you login to your account (https://cp.idimager.com) you should be able to download the newest version of IDimager...
Best Regards,
frith
Post by frith » 28 Jan 10 17:59
I had the same result - created a frozen gray screen.
How do you undo the script?
Frith
sveto
Post by sveto » 28 Jan 10 18:15
In the options just switch back to another interpolation quality.
Sveto
Win7 64bit
frith
Post by frith » 28 Jan 10 18:32
Sveto,
Thanks for this. I assume the specific change is "Tools->Options->Image Viewing/Editing->Image Viewer Optimised For". In the thread above it's a little unclear.
Frith
sveto
Post by sveto » 28 Jan 10 19:23
Yep, that's the option.
Sveto
Win7 64bit
frith
Post by frith » 28 Jan 10 19:37
prophotobooth
Post by prophotobooth » 29 Jan 10 3:46
YAY! Update fixed error with Cd burner - have all the functionality I love again!!! Cheers Hert and co
Post by fbungarz » 29 Jan 10 6:38
is there a way to generally subscribe to the "new version announcements" in the IDI forum. I have the auto update check off because it really slows down startup because of my poor internet connection. Thus I sometimes miss these announcements here. I would like to be able to subscribe to them.
Locked
