Shift+Enter not working
I just updated to the latest build, 7838, on my Windows 11 machine and the Shift+Enter keyboard shortcut no longer opens the selected image in full screen. It has no effect at all, that I can see. I use that shortcut all the time so it's annoying not to have it. I can view full screen by pressing enter to open in Preview mode and then Enter again will open the image in full screen mode but then I have to hit Esc twice to get back to the collection viewer. Can anyone else confirm whether they are seeing the same behavior?
- Contact:
Re: Shift+Enter not working
On MacOS Sequoia, Shift+Enter (Return) does enter the full screen mode.
Photo Supreme 2025; DxO PhotoLab; Affinity Photo; PhotoLine; macOS Sequoia; Mac M2 Studio
Shift+Enter does not work for me on Windows 10, build 7820.
Looks like there's a fix for this in build 7851.
Watch out when upgrading there is an database upgrade involved in going to 7868 release.
The upgrade in 7868 can take a while to complete for larger databases. After completion, your catalog will most likely reduce in size once compacted.G8DHE wrote: 27 Jun 25 10:11 Watch out when upgrading there is an database upgrade involved in going to 7868 release.
OK that's good to hear Hert, its just a bit disconcerting when you run the update and only find out that there is a DB upgrade as the last thing before the program opens! It would be nice if DB upgrades could give a warning before there applied to make a backup - I've never had a problem with one but if I knew before it started I would always run a backup of the DB!
