Renumbering with reset on date change does not work anymore
tumirnix
Post by tumirnix »
in one of the last updates (currently I'm using build 2025.1.3.7602 on Windows) the renaming of images does not work anymore as expected.
The image number is not reset anymore to 1 when the date is changed.
The settings are "offset=1;length=3;increment=1;skip=never;reset=date".
Did anyone observe a similar change?
Best regards
Martin
manusz
Re: Renumbering with reset on date change does not work anymore
Post by manusz »
I am afraid you are right.
I just tested it on Mac build 7607, the reset on date seems to be broken.
This is odd, as I recently worked with Hert on this and it worked perfectly fine in build 7551.
The best you can do now is contact support, see the red banner above for the address.
tumirnix
Post by tumirnix »
Thanks for the confirmation. I will contact Hert.
