Triangle in catalog label corner? [solved]
freudenthaler
Post by freudenthaler »
What's the meaning of the small triangle in the upper left corner of the catalog labels? I tried to look it up in PSu's help document, but didn't find an answer - beside the pictures of green & grey labels? Mine all are in grey...
Re: Triangle in catalog label corner?
They appear because you've set a custom color (grey) as the background for the category. If you like the idea, then you can set different custom colors for each of the default top-level categories in PSU (events, people, etc). If you dislike the feature, set the custom color transparent and the triangles will go.
More here: LAP marker that indicates a Category when the Category uses a custom color
freudenthaler
Re: Triangle in catalog label corner? [solved]
Mke wrote: 29 Mar 25 13:18 They appear because you've set a custom color (grey) as the background for the category. If you like the idea, then you can set different custom colors for each of the default top-level categories in PSU (events, people, etc). If you dislike the feature, set the custom color transparent and the triangles will go.
Oh - thanks for clarification! Wasn't even aware that I could set a color label on the categories. Glad I can get rid of this, looks very nervous & disturbing for me...
