Using the directions from the Feb 20, 2025 version of: https://manualsu.idimager.com/version10 ... nAIAPI.pdf
The steps 3 and 4 suggest running these commands from the command line.
ollama pull llava
ollama run llava
One small tweak.
To run those commands, you must use the CMD in "administrator mode"... or at least I need to.... for them to work as intended. YMMV.
